Ignition timing with a timing light
  • Glen4747
  • Glen4747's Avatar Topic Author
17 Jul 2007 14:02
#157506
Hello, i've finally got my 900 running again. Thanks to everyone that helped out and gave advice. Problem is, its not really running steady. The timing is all out of wack. Anyway, i was wondering if once again someone could lend their help and tell me how to time the new dyna S with a timing light. I know how to use the light, i just don't know how to time the ignition. Thanks again.
-Glen
1976 KZ900 A4
  • KaZooCruiser
  • KaZooCruiser's Avatar
Re: Ignition timing with a timing light
17 Jul 2007 14:13
#157510
Remove timing cover.
Attach gun pickup to #4 and power leads to battery.
Start engine. Rev and lock engine speed @ maximum advance. . .3500-4000rpm.
Shoot light at timing port. Watch for "F" mark to meet stationary pointer. Loosen 3 screws and rotate entire point plate to match "F" mark and stationary pointer.
Lock screws.
Release plug #4, hook to #3.
Same routine, except now to match "F" and stationary marks, loosen bitty allen screws securing 2-3 trigger to point plate, and VERY carefully, slide it as necessary to align timing marks. Tighten bitty allen screws.
Replace timing cover.
You're done.
:lol:
  • Glen4747
17 Jul 2007 16:23
#157539
Should the F mark and timing mark align at 3-4000 RPM or at idle, around 1000 rpm? Thanks.
1976 KZ900 A4
  • The Milkman
  • The Milkman's Avatar
17 Jul 2007 17:20
#157552
KaZoo said, full advance, 3500 to 4000 rpm.
ride safe
  • RonKZ650
  • RonKZ650's Avatar
17 Jul 2007 18:32
#157573
If it's like the KZ650 which I believe it is, you actually time the "F" mark at idle. When you rev the engine you should see the ignition advance and see two more marks '' Timing should fall between these marks at full advance.
