starter lockout switch
- Kevin65
14 Jul 2007 14:04
The switch located at the kickstand is not working properly. It prevents the starter from working and also the horn. As I cannot seem to find a replacement part, can I just jump the two wires? BTW the bike is a 1984 550 F2. Thanks
- loudhvx
Re: starter lockout switch
14 Jul 2007 20:30
Yes you can jump it, but I don't think it should affect the start or the horn. I thought it's designed to kill the ignition if you go out of neutral while the stand is down. Sounds like you may have more than 1 problem.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- gpzrox
15 Jul 2007 04:25
Loud is right.
In reference to the problem does your lights come on with the key on.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- Kevin65
15 Jul 2007 04:39
The lights come on no problem, and with some jiggling of the wire the starter motor kicks in, although maybe something else is being affected during the jiggling process. When the problem happens it affects both the horn and the starter.
- loudhvx
15 Jul 2007 08:38
Unfortunately I don't have an 84 550 F diagram, only an 83 550 F diagram and an 84 gpz550 diagram. But it looks to me like there may be a faulty ground wire to the left handle bar controls. It's black/yellow and gives ground to the horn button and the starter lockout switch (on the clutch lever). But it should still start if it's in neutral, because the neutral switch will provide an alternate ground to the starter lockout (but not the horn button). It's possible that jiggling the kickstand switch provides a ground to the diode array, which then provides a ground to the starter lockout switch, which then feeds a ground to the horn switch to make it all work.
If you short the kickstand wires together does everything work normally?
Does the neutral indicator work? Will it start while in gear if you pull in the clutch lever?
The 84 models in North America have a bunch of lockout/diode-array safety circuits which can cause a whole bunch of mysterious and seemingly crazy symptoms. They can all be bypassed with a little research and time. If I had an 84 550 F diagram I could tell you what to do.
Post edited by: loudhvx, at: 2007/07/15 11:42
1981 KZ550 D1 gpz.
Other links.
Other links.
- Kevin65
31 Jul 2007 15:19
Thanks everybody - problem solved. I held down the horn button and moved wires until it honked. Turned out it was the left handlebar switch, so I disassembled it and cleaned all the contacts. Nothing was obviously broken or loose but it could have been dirt. Also painted the cover while it was empty. Looks good and the bike finally runs. Two new tires and a safety check and I will be on the road. Again a big thanks.
