Re-Wiring Switches Help
  • Muddy
  • Muddy's Avatar Topic Author
10 Jul 2007 13:53
#155998
I'm getting ready to re-wire my switches. I decided to use late model gsxr/tl/busa switches as I like the way they look. I'm not the most electrical minded guy so I need some help deciding what wires to splice together.
I'm planning to cut the connectors off the original CSR switches and wire the new ones to the old connector and then just plug them together.
Here is a link to the wires on the new switches. www.hifidefinition.com/berman/kz/switches.jpg
I need the starter, horn, light dimmer, engine stop, turn signals.
What wires from the old harness and new switches need to be connected?
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Re-Wiring Switches Help
10 Jul 2007 15:02
#156003
You should grab the CSR wiring diagram off the Filebase, and see what colors go to what switch, then use that info to decide what wire needs to go to the new Suz control. The colors aren't going to match up, so keep notes.
Good luck and let us know how it goes.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • Muddy
10 Jul 2007 18:40
#156039
What would I do for functions that are not supported on the new switches? IE Headlights on/of
  • 77Davo650
  • 77Davo650's Avatar
10 Jul 2007 21:58
#156065
You could just have the headlight controlled by the ignition and eliminate the need for the on/off switch. Or just make a switch you can tuck away out of sight that is not on the handlebars. I made a switchbox on my 650 since i took the handlebar controls off, it tucked away behind where the steering meets the double downtubes on my bike, there was enough room to squeeze it in there. Accessing the switches easily while riding was a different story however...
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
  • wiredgeorge
  • wiredgeorge's Avatar
11 Jul 2007 04:54
#156091
I have done this type of conversion in the past; you get to do this conversion when you use a wiring harness with the wrong switchgear (non matching). I pretty much know what I am doing and it would take me best part of a day to think my way through the issues and do the actual soldering and rewiring. If you are not comfortable with wiring diagrams and the function of the various electrical bits involved, you might want to reconsider t his project.
  • OKC_Kent
  • OKC_Kent's Avatar
11 Jul 2007 05:57
#156105
By 1982 weren't the headlights on all the time anyway?
Cashion, OK
  • wiredgeorge
11 Jul 2007 13:06
#156190
They started to hardwire headlights in about 78/79 I think. My 79 KZ1000E1 has hardwired headlights.
  • Muddy
11 Jul 2007 17:06
#156242
I could have sworn that the left switches had headlight on/off?
