Used Dyna III worth $50.00? UPDATE!!
- bkitchen
01 Jan 2006 21:00
I have found a guy who has a Dyna III system off a running bike for $50.00. Is this a good deal and is there anything I should look for?
Post edited by: bkitchen, at: 2006/01/19 13:10
- loudhvx
Re: Used Dyna III worth $50.00?
02 Jan 2006 11:32
They were in the $150 range when they were last available. At least that's what I paid.
Personally, I think the design of the III is better than the Dyna-S. It has a big aluminum case for heat dissipation and the control box is away from engine vibration. The tradeoff is that you have to find a place to mount the big box and there is more wiring to deal with.
As far as possible damage to look for:
Look at the pickup assembly very closely for cracks in the circuit board.
Also look for physical scuff marks for where the rotor may have collided with the pickups (usually happens when the bike gets dropped hard on the right side).
As usual, look for any signs of burnt wiring.
It should be a pretty hearty system. The ignition coils must be 3-ohm or higher (in case you are swapping to another bike).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- bkitchen
02 Jan 2006 12:28
I'm sticking with the stock coils for now, they seem to be doing fine. Thanks for the Info.
- PuGz
02 Jan 2006 12:48
My experiance with Dyna III's has been when they die there is no way to tell becase the "goods" are sealed in epoxy. However $50 is not bad.
- wiredgeorge
03 Jan 2006 06:59
Off a running bike? HEY I THINK I HAVE BOUGHT FROM THAT GUY!!! Bwhahahaha Sorry, I have a WHOLE box of useless electronic JUNK that came off QUOTE running bikes UNQUOTE! Jeff at
www.z1enterprises.com
sells Dyna S units so cheap now, that I don't see a good reason to buy a used ignition.
- bkitchen
Re: Used Dyna III worth $50.00? UPDATE!!
19 Jan 2006 10:12
Finally got a chance to get it on and it FIRED RIGHT UP! Got it timed and went for a short ride today. Finally got to 55 degrees too.:laugh: Seemed to idle better,run smoother at lower RPM's, and pull harder all the way through.
- patmann
19 Jan 2006 13:44
Some people have all the luck when buying used parts:P
good for you !!
Pat
good for you !!
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
