Jumpstarts and then dies
  • mbhudson
  • mbhudson's Avatar Topic Author
08 Jul 2007 07:41
#155434
So I have an electrical question/problem. After a couple of days without riding my 650 it wouldn't start. I jump started it and while the jumper cables were connected to the 'donor' vehicle it started fine. However as soon as one of the cables was disconnected the bike immediately died. I tried disconnecting the battery, cleaning connections, but still no go. So is it the battery or alternator? Any help would be great!?
  • anarki650
  • anarki650's Avatar
Re: Jumpstarts and then dies
08 Jul 2007 07:44
#155435
My money's on the battery, or at least that the battery is part of the problem. If you have a hydrometer, check your battery cells and see if they are all good (I'm betting at least one of them is not). If you don't have a hydrometer, take the battery to an auto parts store and have them check it for you.
Once you get a good battery in it, start it up and check the voltage at the battery to see how your charging system is doing. If it's not above 13 volts at idle and about 14.5 at 3500-4000 rpm then you've most likely got a charging system issue.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • gpzrox
  • gpzrox's Avatar
08 Jul 2007 14:16
#155484
careful jumping off of a car, it will smoke the stator. Stators can be expensive.
My motorcycle shop had a load tester, took 2 minutes to check.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
  • BSKZ650
  • BSKZ650's Avatar
08 Jul 2007 14:28
#155490
check the battery, it may be dead, you also need to check the charging system also, you may have a problem there also
77 ltd1000, current rider
76 kz900, just waiting
  • loudhvx
  • loudhvx's Avatar
08 Jul 2007 17:27
#155515
Just make sure the car is not running.
