Where should i run the ground wires to?
- oldkaws4ever
- Have no regrets...... You only live once.
05 Jul 2007 01:38
well when i changed the battery cables, i somehow broke the bolt securing the ground cables to the motor, can anybody here tell me a good solid place to ground the battery cable ?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Snakebyte
Re: Where should i run the ground wires to?
05 Jul 2007 05:24
Motor mount, cover bolt, v cover, starter cover,
- wiredgeorge
05 Jul 2007 05:25
You can always remove the broken bolt and mount the ground to the engine cases as the original designers thought best. If you don't want to do that, there are bolts on the battery box mount brackets that will work. Make sure that the ground touches metal and not paint.
