- Thank you received: 5
points ignition
- jordan
03 Jul 2007 11:02 #154500
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
points ignition was created by jordan
I have an 82 750 motor that I put into a 78 650 frame. i used the points ignition from the 650, but I dont think that it works. With the cover off, shouldnt you be able to see a spark from the igntion when you turn the motor over? And also, the points move, but not very much when the motor is turning over? PLEASE HELP!!!!
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- mariozappa
- Thank you received: 8
03 Jul 2007 12:24 #154512
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic points ignition
What was wrong with the electronic ignition that came in the 750?
1977 KZ650C1
- ABR
03 Jul 2007 13:48 #154526
by ABR
Replied by ABR on topic points ignition
No if you see sparking that is BAD. It means your condensers are fried, or not hooked up right.
The points should be .3-.4 mm apart at max separation (the 650 toolkit comes with a feeler for this width) and touching at the opposite side. You also need to set the timing -- refer to a manual here, you can do it either with a timing gun (easiest) or roughly with an ohmmeter.
