'83-84 GPZ1100 tank LCD warning unit
- darmahsd
01 Jul 2007 21:09 #154155
by darmahsd
'83-84 GPZ1100 tank LCD warning unit was created by darmahsd
I would like to take the LCD warning unit (fuel gauge, stand, efi etc.), off of it's pseudo chopper position on the tank and mount it up in the fairing where it should have gone in the first place. I will grind the mounting tangs off for a smooth tank. IMHO a sensible mod that won't butcher the bike if done right. I'm going to have to lengthen all the wires to get it to reach out to the front.
Would any electronics expert out there know if the electronics in that unit will be sensitive to the added resistance of lengthening the wires and malfunction? I wouldn't know how to test one unless I actually make a removable harness that would make it possible to take readings without the unit being a guinea pig.
Thanks,
Stephen
Thanks,
Stephen
- loudhvx
- Thank you received: 1615
01 Jul 2007 23:19 #154165
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic '83-84 GPZ1100 tank LCD warning unit
Longer wires shouldn't matter, but vibration may possibly become an issue.
1981 KZ550 D1 gpz.
Other links.
- darmahsd
02 Jul 2007 15:57 #154312
by darmahsd
Replied by darmahsd on topic '83-84 GPZ1100 tank LCD warning unit
Nothing to vibrate, solid state digital unit. But it will be suspended, as all of my motorcycle installations
are. Being the owner of a few British bikes in the past, I know something about vibration. Also Lucas, the prince of darkness:)
- darmahsd
02 Jul 2007 15:59 #154314
by darmahsd
