voltage variations
  • Dave Sloan
  • Dave Sloan's Avatar Topic Author
voltage variations
30 Jun 2007 17:42
#153971
HI Guys,
Can anyone tell me how much variation in voltage the voltage reg allows? I have been checking a few things on the logs that I take while riding ( with a palm pda ) and noticed that voltage goes as high as 17.5 volts at high rpm. Is this normal?? :unsure:
Z650B2 - Injected
Re: voltage variations
30 Jun 2007 19:16
#153981
That's too high. Here's how to test voltage regulator: Check battery voltage with engine off - must be at least 12v to continue. Unplug 9 pin connector in headlight shell and turn off or unplug any lights. Hook v meter up across battery and start engine. Bring RPM up to 1600; voltage should be between 14 - 15v. Without letting RPM's drop, gradually bring RPM's up to 4000; voltage should stay between 14 - 15v. Voltage should exceed 15v at any RPM. Ed
  • loudhvx
  • loudhvx's Avatar
01 Jul 2007 22:59
#154161
If you have an instantaneous voltage log, 17.5 is not out of the question. The average voltage, (which is what meters read) should peak around 14.5, but I found the instantaneous voltage can easily spike to over 16v.
Post edited by: loudhvx, at: 2007/07/02 02:00
