- Thank you received: 4
INVADED BY NEGATIVE! *dumbfounded*
- themachine
29 Jun 2007 19:26 #153783
by themachine
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
INVADED BY NEGATIVE! *dumbfounded* was created by themachine
i'm ready to give up, i put my electical tester on the positive + post on my battery terminal, then turn the key on and stick the other in my headlight clip (i'v tried all three) they all rate at 12.8 volts
its like this everywhere, negative power where positive should be, the starter solinoid shows that its working when i check it backwards.
every clip in the igniton switch plug has negative running through it.
my guess, and only guess is that a positive wire got melted by my negative igniter wire and is picking up off of that or something else, anyone else have any ideas for an electical noob.
its not the fuse box, i unhooked it and still found negative running around
i'm going to have some captain and coke to calm down befor i take a BFH to my bike.
:S
Post edited by: themachine, at: 2007/06/29 22:39
Post edited by: themachine, at: 2007/06/29 22:47
:S
- pstrbrc
- '81 GPz 1100 project
- Thank you received: 9
29 Jun 2007 20:06 #153793
by pstrbrc
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Replied by pstrbrc on topic INVADED BY NEGATIVE! *dumbfounded*
Wow. I'm thinkin', I'm thinkin'.
What did you do right before this? What changes have you made? What were you working on last?
Elkhart, Kansas USA
- steell
29 Jun 2007 20:46 #153798
by steell
Replied by steell on topic INVADED BY NEGATIVE! *dumbfounded*
You have a wire grounded to the frame somewhere, I'd start looking at the wiring under the tank.
- themachine
29 Jun 2007 22:05 #153816
by themachine
Replied by themachine on topic INVADED BY NEGATIVE! *dumbfounded*
i fix'd it, i found another burnt wire.
this is my third topic on this damn thing.
