- Thank you received: 1
750B wiring prob
- agawam
28 Jun 2007 17:43 #153506
by agawam
750B wiring prob was created by agawam
My 79 750 twin has developed a problem, it burned up the reg/rec, coil, headlight and tail light last fall so I put it away till I could get to it, so I put in all good stuffand it ran seemed like no problem I rode it for a while then it burned the reg/rec, so I got another one and with the bike switched off when connecting it the wire got real hot(the one from positive cable)so scince I had the stuff I replaced the stator,starter sol,right control switch and I tried the positive reg wire again ,same thing real hot turned red,I disconnected the stator no spark(this is another stator remember)no short, reconnected the stator and disconnected the other wire, short again any ideas
- agawam
01 Jul 2007 19:18 #154126
by agawam
Replied by agawam on topic 750B wiring prob
found it, bad regulator sometimes the parts in the bin aren't always the best
