is it possible to....
- themachine
26 Jun 2007 15:17
is it possible to hook the stator up wrong and bake out the voltage regulator and fry a wire going to the ignter? and has anyone ever burned up an igniter?
Post edited by: themachine, at: 2007/06/26 18:17
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- steell
Re: is it possible to....
26 Jun 2007 16:28
If it was hooked up wrong so that 60-80 volts AC was being fed to the bikes wiring system, then I'm pretty sure that it would fry an igniter and a regulator.
- themachine
26 Jun 2007 18:13
there were three wires, all tan, one was a female clip, the other two were male clips
- wiredgeorge
27 Jun 2007 05:33
Is this a hypothetical question or are you referring to the J motor bike in your sig? I am pretty sure it doesn't matter which wire goes to which connector on the reg/rec other than one has a different connect.
- loudhvx
27 Jun 2007 07:49
Is it normal for one of the clips to be different from the other two? I mean, is that stock? I wouldn't have expected that. If the wires are the same color it shouldn't matter, but the odd clip is strange.
There are scenarios where the order of the alternator wires matter, but that was only on some older regulator designs. By 1982 I don't think the order should have mattered.
Post edited by: loudhvx, at: 2007/06/27 10:51
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- wiredgeorge
27 Jun 2007 12:52
I have a J motor up in the shop and have changed stators and don't recall one of the plugs female... it has been awhile though...
- themachine
27 Jun 2007 16:36
yes one of the wires on my J motor has a female clip, i
m just trying to figure out why my bike has no power and why i burnt up a negative wire that lead to my ignighter.
i'm not the brightest bulb in the pack when it comes to electrical things.
