Hard Wired Coils?
  • Z1Boise
  • Z1Boise's Avatar Topic Author
Hard Wired Coils?
25 Jun 2007 19:12
#152685
I've got a '75 Z1B 900, and I was planning to change the spark plug wires. However, they attach to the coils pretty firmly, and, even though there is a boot over that connection, the plug wire fits so tightly that I wonder if it could be hard wired. I'm reluctant to just yank the h*ll out of it until it comes loose. That technique has caused me much grief in the past.
Does anyone know whether it might be hard wired? Should I just grab and pull like a mutha? Shown below is the plug wire as it connects to the coil, bit the boot folded back.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Hard Wired Coils?
25 Jun 2007 19:22
#152687
If their like my '78 650, they're not meant to come out. :(
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Z1Boise
25 Jun 2007 19:53
#152700
So, new plug wires means new coils? $#!+.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
25 Jun 2007 19:58
#152701
Well, there are NGK splicers you can find on ebay (I bought a set my self), you can also just cut back about a 1/2 inch of wire off the end to get rid of the corrosion.
Or, if you want to get all the milk outta that Z1 kaw, then yes, get some new coils... and wires...
:laugh:
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
25 Jun 2007 19:58
#152702
Here's a plug wire splicer from Z1E. :)
splicer
  • Z1Boise
25 Jun 2007 20:36
#152712
How did the splicers work? Get an improved spark?
I'm fighting a sooty plug problem, so spark is important to me. Tried the wiredgeoge relay, which helped, but still having a stumble at low rpm, and the 3rd cylinder runs cooler than the others. 3 of 4 plugs sooty.
I guess I can spring for a new set of coils, but dang it, a guy ought to be able to change spark plug wires without buying coils as well.
I do appreciate the link to the splicers, and the info.
  • Biquetoast
26 Jun 2007 03:16
#152745
I'm fighting a sooty plug problem, so spark is important to me. Tried the wiredgeoge relay, which helped, but still having a stumble at low rpm, and the 3rd cylinder runs cooler than the others. 3 of 4 plugs sooty.....
The splicers are njust like you'd imagine them to be - you cut the wire wherever you want, attach the splicer, then attach your new wire to the other end. The only problem is, you have to be certain that (a) your coil is still good and (b) you're certain you've cut out the bad part of the wire. I ended up going that route...
I had the exact same symptoms a while back. For me, the relay mod solved my sooty plug problem. Before that, I was like 99% certain the carbs were set correctly, but couldn't get rid of the sooty plugs. So the realy mod is the second best change I made to the bike.
After the relay mod, I still had the stammer/stumble problem, most notably at lower idle. Then I started to realize the problem was worse as the bike was warmer... so I sprung for a dyna coil and some wires, and viola - no more problem. The coil replacement was the single best change I made to my bike(s)...
kz750twins.com
  • beardog63
  • beardog63's Avatar
26 Jun 2007 03:18
#152746
i used the splicers to put new plugs and caps on my 75 z1 made a big difference!:laugh: :P
  • Z1Boise
26 Jun 2007 12:14
#152878
I'm leaning toward springing for new coils. The splicers would be $30, and that's a good chunk toward new coils.
The bike sat for 6 years, some in garage, some outside. I got the carbs cleaned up, and katjbus synced them for me so I think the carb piece is in pretty good shape, but it's still stumbling around 2-3k, and still fouling the plugs.
So I'm thinking, what type of stuff goes wrong when the bike just sits, because it ran great when I parked it. That line of thought led me to conclude that the connections could corrode, and rubber deteriorate, etc, implicating the electrical system. Valves wouldn't go out of adjustment, though I'm going to check them in the next few days.
A thought; I recently insulated the baffle in my kerker 4-1 exhaust to quiet it down. I wonder if that would reduce exhaust airflow, thereby making it too rich. I'll try it without the insulation for a bit before I order the coils.
Here's a decent sized pic of the bike. Notice how the sun has faded the side plastic covers and turned them green. Same way on top of the tank.
  • Biquetoast
26 Jun 2007 15:35
#152920
Z1Boise wrote:
...Here's a decent sized pic of the bike. Notice how the sun has faded the side plastic covers and turned them green. Same way on top of the tank.
kz750twins.com
  • themachine
  • themachine's Avatar
26 Jun 2007 15:44
#152923
Biquetoast wrote:
looks like a british racing gren now :cheer:
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
