ignition wire getting hot?
  • basscatnc
  • basscatnc's Avatar Topic Author
25 Jun 2007 06:29
#152512
on my 77 kz1000 the ignition wire has been getting hot, when i got the bike there was no fuse and the wire's were just put together, it got hot then also, but to be on the safe side i put a fuse in it and it still gets hot, is this normal or not?
Thanks,
Mike
  • wiredgeorge
  • wiredgeorge's Avatar
Re: ignition wire getting hot?
25 Jun 2007 07:05
#152524
Could you explain what an ignition wire is?
  • basscatnc
25 Jun 2007 07:24
#152531
The wire going to my fuse box that says ignition. im guessing it's coming from the switch. mainly getting hot around fuse connection.
thanks,
Mike
  • basscatnc
26 Jun 2007 06:44
#152785
any idea's?
  • wiredgeorge
26 Jun 2007 08:02
#152801
Since I don't know what type bike is being discussed, I am going to assume glass fuses? The short ones should be used and folks generally try to use longer ones when the short ones are not available... bad fuse connection. The fuse holders are mostly all half-melted in most old fuse boxes and it doesn't do any harm to head down to the auto parts store and buy a new fuse holder that holds blade type fuses. Don't know how many are needed but the main fuse (20A) holder should be rated for at least 20A and that will be the big white wire going to the ignition switch and the other, smaller fuse holders are typically 10A. It should have enough slots to accomodate the same number of fuses as your current box has in it.
