KZ650 1 cylinder not working.
24 Jun 2007 13:24 #152342 by takuma
KZ650 1 cylinder not working. was created by takuma
I just got a 1980 KZ650 and 1 of the cylinders are not working. It is the 2nd or 3rd one I can make sure later. The spark plug is not getting any electricity. I believe it is the coil.
I was just wondering if anyone else has any ideas about this? Also anyone know where I can get a Coil for a good price. Also does anyone know if there are other coils from other bikes that would work?
Thanks alot.
  • RetroRiceRocketRider
  • ...bring in the machine that goes PING!
24 Jun 2007 15:31 #152376 by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic KZ650 1 cylinder not working.
Welcome to KZr takuma.
If the coil was bad, it wouldn't send power through to the other spark plug.
First try replacing the spark plug with another one (new plugs have been known to be defective at times).
If no spark still, then unscrew that spark plug cap and place the end of the plug wire against the cylinder as you hit the starter button (carefully keeping your hand far enough away from the end of it :pinch:).
If you get spark now, then either the plug cap is faulty, or simply wasn't making contact with the wires.
If you trim back about 1/8" off of the end of the plug wire, you can "renew" the spot where the plug caps threaded stud screws into it.
If still no spark though, then check to see if that plug wires is damaged and causing your prob.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
24 Jun 2007 15:50 #152379 by OKC_Kent
Replied by OKC_Kent on topic KZ650 1 cylinder not working.
Welcome to KZRider!
The 650 has two coils, and one fires cylinder 1&4, the other fires 2&3. If one plug fires, either 2 or 3, then the coil is probably good. You may have a bad wire/cap or a bad plug.
Remove plugs 2&3, and see which spark plug is firing. Remember to keep them laying on the head, or touching the head somehow..
Then switch the plugs to see which one fires. If the same wire keeps firing then you'll know the plugs are good and the dead wire needs help.
It is not uncommon for plug wires to corrode on the end that fits in the plug cap. You can gently twist and pull off the plug cap and clip off 1/4" of a corroded plug wire and often get a good spark again. If this works then all is good.
If clipping the wire does not work then remove and swap caps. If the dead wire works after the swap and the other wire doesn't then you narrowed it down to the cap, and can buy a new one.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
24 Jun 2007 19:39 #152426 by takuma
Replied by takuma on topic KZ650 1 cylinder not working.
Thanks alot guys. I'll check that stuff out tomorrow hopefully.
However I assumed those weren't the problem because I checked each wire with a timing light gun. The 3 working ones made it flash but the nonworking one didn't do anything.
26 Jun 2007 08:55 #152823 by takuma
Replied by takuma on topic Re. Coil
I checked the wires and they were fine. I was wondering if anyone knew if this coil would work on my KZ650
cgi.ebay.com/ebaymotors/USED-Ignition-Co...QQrdZ1QQcmdZViewItem
Or do you know any other inexpensive Coils I can replace it with.
Thanks alot.
26 Jun 2007 10:58 #152862 by OKC_Kent
Replied by OKC_Kent on topic Re. Coil
They may work, not sure tho..Lou would know, send "loudhvx" a PM, he knows 550's and ignition electrics better than most.
Oklahoma City, OK
