Wire equivalents
- Gidian9
Wire equivalents
21 Jun 2007 12:28
I have an 82 KZ440. The wire that runs from my solenoid to the starter is apparently cracked inside the insulation because at times it will give out and the bike will not have sufficient power to start. The dealer want to charge me 45 dollars for the part and I think that is crap. Does anyone have any suggestions about equivalents or the best way to fashion something like that?
1982
KZ440 LTD
KZ440 LTD
- OKC_Kent
Re: Wire equivalents
21 Jun 2007 13:35
Gidian9,
I sent you a PM.
Kent
I sent you a PM.
Kent
Cashion, OK
78 KZ650 B2 85,000+ miles
- wiredgeorge
21 Jun 2007 20:34
Sure; go to the autoparts store and buy a long 6 gauge multistand battery wire... either positive or negative depending on whether you like red or black. Many autoparts stores sell corresponding brass battery terminal connectors which will work fine; you might have to use a steel washer to make them fit the lugs on the starter and solenoid. The brass connectors are fit on the conductor after stripping a bit of insulator and you crimp them with a punch. One of these battery cables will cost less than $5. They sell battery cables in a variety of lengths and I generally buy enough to make up a bunch of ground and hot cables...
- PLUMMEN
21 Jun 2007 20:49
or if you know any electricians talk one out of some fine stranded 4ga wire.automotive cables tend to have coarser strands of wire which has more resistance and doesnt hold up as well to vibrating bikes tend to do;)
