KZ750B - Battery Suggestions?
- mind2find
21 Jun 2007 07:57
Hi all,
I'm about to replace my (acid leaking) battery. I'm uneducated about the brands and reasonable pricing in this market.
All I have so far is:
www.ebatteriestogo.com/landing_pages/powersport/UB14L-2.htm
Are any of these brands good? Are there better ones? Are these reasonable prices?
Thanks as usual guys!
1976 KZ-750B1 (late model)
1976 KZ-750B1 (early model) Parts Bike
Boston, MA
Boston, MA
- Biquetoast
- King Jeremy The Wicked
Re: KZ750B - Battery Suggestions?
21 Jun 2007 08:36
mind2find wrote:
However, I can offer that I just go up to my local AutoZone, and pay much less than that for a generic battery that seems to last quite a while when well cared for (like a Battery Tender, which is what I use, or similar). Once I had what I think was a bad battery off the shelf, and they replaced it, no questions.
My thinking is this: As long as it works, fits (poles on the correct sides, correct height, width, etc.), holds a charge, and holds together, it's fine for me. Sometimes you need special batteries for special applications (like if you're mounting it on its side, etc), but not me....
Post edited by: Biquetoast, at: 2007/06/21 11:38
Unfortunately, I do not know the answer to any of your questions....Are any of these brands good? Are there better ones? Are these reasonable prices?...
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- Virii
- I like cheese
21 Jun 2007 13:08
I've always just grabbed some cheap YUASA or what have you from the shelves as Biquetoast mentioned. Never had a problem.
Unless you have a specialized application or you want to try to up your specs (are you mean to your battery? neglectful? pull a TON for a really hard starter? call it names?)
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
