'95 Vulcan 500 (en500) coils on a '79 KZ 750?
  • Jornum1
  • Jornum1's Avatar Topic Author
19 Jun 2007 13:08
#150912
Does anyone know if I can swap EN500 coils into my '79 KZ750? I got these for free, they are from a bike that only had 2500 miles on it. I just dont know what the specifics are of these coils.
Any insight would be great,
Thanks,
Jay
  • katjbus
  • katjbus's Avatar
Re: '95 Vulcan 500 (en500) coils on a '79 KZ 750?
19 Jun 2007 13:18
#150913
you should match resistance readings, the replacement coils should have lower or less resistance than the ones you are replacing never more or you can burn up your ignition system
  • Jornum1
19 Jun 2007 13:58
#150919
Thanks, does anyone know some resources for specs on this bike, or particular coil? I have done several searches, but cant find anything.
Thanks for your help.
  • loudhvx
  • loudhvx's Avatar
20 Jun 2007 05:24
#151065
It's the other way. Coils with too little resistance will burn up points or ignitions. Your 79 750 is probably points. In that case, those coils will shorten the life of the points, unless you also use a ballast resistor.
