fuel level sensor
- newbikekiller
fuel level sensor
18 Jun 2007 07:36
Hi all. I'm just wondering if anyone has an Idea how the low fuel level sensor on our bikes work? - its a 1982 Kaw KZ 650.
The bike itself is fine - but I'm actually trying to figure out a better (cheaper) way to detect low oil LEVEL in large medium speed two-stroke marine diesel engines (I'm interning at Electro-motive diesel www.emdiesels.com )
There is a lot of crap out there to monitor low fluid level, but none so elegant and simple as the one that is installed on the later Z's.
Right now we cut a hole in the oil pan, weld in a huge metal tube, and then install a float sensor (its like your toilet bowl float, only in a vertical arrangement) over that.
Moderators - if you want to put this in chit chat I understand
P.S. - I am not attempting to reverse engineer and I'm not going to be violating any patents
Post edited by: newbikekiller, at: 2007/06/18 10:48
- kzwolfsr
Re: fuel level sensor
18 Jun 2007 07:48
I am a fox at this one. Think of using a magnet or using electrical resistance. I can't tell you more since my mind is full of genius ideas. Went to school to do diesel technology, to fix trucks.
Original man of the Caribbean
- newbikekiller
18 Jun 2007 07:59
It's not immediately apparent to me how a magnet would help.
Actually most old school fuel gauges work by having a mechanical device (float) run up over an electrical strip thereby changing its resistance. Doesn't help much though because thats comparing apples to apples with what we already got
- kzwolfsr
18 Jun 2007 09:26
Use a magenet as your sensor. The magnet is on the lowering and rising object on your guage and as it passes certain points it opens a circuit which lowers your needle to a electromagnetic point on your meter, Ya get me? You have to think more, and stop having me do your homework!
- newbikekiller
18 Jun 2007 09:47
Yep.
But the ones on our bikes have no moving parts
and are so cute and tiny and easy to install!
Thats what I'm really interested in. I may just have to do some investigating with some of the electrical engineers around here to come up with our own device. Right now I was looking to buy one from somewhere else :whistle: we'll see. I've seen around 200 vendor's stuff and I'm at the end of my rope trying to find an elegant solution to this. I should have looked at KZ's first!
I'll let you guys know exactly what I find out... maybe it will help ya'll if your sensor is bad or if you want to redesign it (possibly a real gauge instead of just a low-level alarm).
- N0NB
- Blue handles better
18 Jun 2007 09:53
My guess is that the fuel sensor on the bike is simply measuring the difference of resistance between fuel and air. I don't have any first hand knowledge of that, and mine quite anyway a couple of years ago. I wouldn't mind figuring out some way to fix it, though.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- newbikekiller
20 Jun 2007 06:42
Can't help but do a bump here. I'll bet someone knows for sure how this works... Any takers?
- wiredgeorge
20 Jun 2007 12:20
You lost me when you were about to cut the hole in your oil pan to install the fuel level sensor... What is a fuel level sensor? Is it connected to a gauge?
- Corith
20 Jun 2007 13:29
Why not just use a scale and weigh the mass above it. Or use some type of barometric pressure. As the gas tank gets full, weight/barometric pressure increases.
- newbikekiller
10 Jul 2007 09:54
We are probably going with something like this
www.gemssensors.com/content.aspx?id=1144
Optical, cheap (as this goes, its still >$100) , and small. You could probably use this on a Z if you were so inclined to replace the stock unit.
I still have NO IDEA how the KZ ones work.
