Dyna electronic ignition diagram
17 Jun 2007 20:44 #150301 by brich
Dyna electronic ignition diagram was created by brich
anyone have a scan of the directions and diagram that comes with a dyna electronic ignition? it is for a 75 z1900.
thanks
brian
1975 Z1 900, 1075 wiesco kit, web cams, smooth bores, dyna ignition, denco pipe, lester mags, wicked bad rotors, custom gauge face plates .. not much stock left.
17 Jun 2007 20:55 #150304 by Sandy
Replied by Sandy on topic Dyna electronic ignition diagram
Which Dyna ignition are You talking about Bud?
I can get You the diagram for the "Dyna2000"...it might be the same...
1977 KZ1000 A-1
17 Jun 2007 21:03 #150307 by Sandy
Here,I'll post it anyway,as the coil-wire colour might be the same as what You have...
If You need the directions,just send Me a u2u with Your email addy,and I can email it to You.
Post edited by: Sandy, at: 2007/06/18 00:04
1977 KZ1000 A-1
18 Jun 2007 04:42 #150351 by BSKZ650
Replied by BSKZ650 on topic Dyna electronic ignition diagram
you can go to the dyna site, hit the tech section and the have instructions and a flow chart
77 ltd1000, current rider
76 kz900, just waiting
18 Jun 2007 16:17 #150666 by brich
Replied by brich on topic Dyna electronic ignition diagram
truthfully, not even sure which model. I bought it when i was 17 and first put that bike together. Now at 33 i am putting it back together again!
I dont have the module. Just the ignition and wires right to the coils.
Thanks for the info though. I will hit up the Dyna site and see.
Thanks guys!
-b
19 Jun 2007 12:09 #150900 by OnkelB
Replied by OnkelB on topic Dyna electronic ignition diagram
If you have no module it´s most likely a Dyna-S. Pretty simple to wire up: red wire is (switched) 12V power supply to the pickups, looking at the ignition plate the wire coming off the left pickup connects to the 1/4 coil, the wire from the right pickup connects to the 2/3 coil.
77 KZ 650 B1, 82 GPz 1100 B2.
20 Jun 2007 00:28 #151044 by AR15Ron
Replied by AR15Ron on topic Dyna electronic ignition diagram
Make sure you follow the directions above and NOT the diagram by COLOR on the Dyna site! Mine was totally backwards and I guess it is common. If yours is the same and you just follow the directions the bike won't run! (it will backfire like a rifle shot though) Ignore the colors and go by left/right pickups instead!
