Stator Magnetism
- hobodan
Stator Magnetism
17 Jun 2007 17:29
So, I did a bit of testing from everything I have read. When I connect an ac volt meter between the yellow wires from the stator I get at idle .3 VAC. Not good.
at least all of them are the same...
Anyways, I am suspect that it might be the magnet. It is very weak and barely pulls a screwdriver towards it.
Has anyone ever heard of this before? Perhaps I am doing something wrong?
Thanks!
Thanks!
1977 KZ650-B1 frame and engine. Random pile of parts for the rest.
- hobodan
Re: Stator Magnetism
17 Jun 2007 23:02
never mind, I'm and idiot! needs 12v to generate the magnet...
admins, if you would like to remove, please do so!
Thanks!
Thanks!
- wiredgeorge
18 Jun 2007 18:46
Ain't that bad a question... the magnet can go dead (lose magnetism) if you bang it hard with a hammer or heat it. I have had to replace them in the past.
