Help!! - electrical problem
- Kevin65
17 Jun 2007 13:05
I have spent the winter painting and polishing my 550 LTD F-1 and believe I have touched nothing electrical. The bike ran fine in the fall. The problem is that there is power to the fuses with the ignition off, but when I turn the key I lose power to the fuses (using a test light). I have checked everything and nothing appears to be disconnected or shorting. Any ideas?
- BSKZ650
Re: Help!! - electrical problem
18 Jun 2007 04:45
power to fuses with the key off?? something aint right there, you should have no power with key off, did you have the key switch out during the clean up?
77 ltd1000, current rider
76 kz900, just waiting
- loudhvx
18 Jun 2007 05:57
The main fuse, (and the accessory fuses) get power all the time from the battery. The other two fuses are for lights. They only get power when the key is on.
How are you hooking up the test light?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- BSKZ650
18 Jun 2007 09:37
I was thinking no power to fuses while in the off, my bad
- Kevin65
18 Jun 2007 15:32
Thanks for the replies. I am using a test light hooked to the negative battery post and the other end to the fuse. When I turn on the key I have no power anywhere.
- PLUMMEN
18 Jun 2007 23:24
that makes no sense,you should have power through the main fuse that powers ignition switch.from there it is split to differant areas of bike which are affected by switch being on/off;)
- AR15Ron
18 Jun 2007 23:36
Umm, dumb question, is the battery charged? If the battery is pretty much dead you might have enough power to light the test light, until you turn the key on and power goes to the ignition coils taking what little is left from the battery. Just a thought
- PLUMMEN
18 Jun 2007 23:48
no thats way too simple,we need a really complicated explanation!:ohmy:
- Kevin65
19 Jun 2007 17:11
Actually, I recharged my battery from dead, it did'nt hold a charge first time and I noticed the acid level was low so I filled with distilled water and recharged, assuming that the battery was now charged. I will try my neighbours booster battery and possibly that is my problem. I will let you all know this weekend. Thanks!!!
- loudhvx
20 Jun 2007 05:33
It could be what AR15Ron said (which is most likely), or it can be a bad connection somewhere between the battery (+) and the main fuse. Many times it's the actual battery connection.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Kevin65
