5 degrees ignition difference
  • martijn
  • martijn's Avatar Topic Author
17 Jun 2007 12:06
#150219
Today I was inspecting the ignition timing. I do have a dyna S. I used to set the timong just by rotating the 17mm nut with a wrench. So it was exactly on the F mark.
Today I used a stroboscobe to check the timing and I noticed it was approx 4-5 degrees before the F mark (At 1100rpm)
Then I found that there is some play in the mechanism.
What should I use as reference the static timing or when running???
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 5 degrees ignition difference
17 Jun 2007 12:22
#150225
id say running since that is when advance takes place ;)
  • Mark Wing
  • Mark Wing's Avatar
17 Jun 2007 12:50
#150231
I say running also.
Mark
Yorba Linda Cal.
