new headlamp kinda weak
- fallenknight308
- When in doubt, use a hammer!
16 Jun 2007 16:08 #150032
by fallenknight308
[img=http://img9.imageshack.us/img9/4085/kz650011.th.jpg]
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
AND I KEEP ON POURING THE $ INTO IT!
new headlamp kinda weak was created by fallenknight308
I just got a acerbis diamond headlamp
( www.acerbis.com/p107_headlight/3001.html )
, wired it up, and noticed its on the weak side,
Is there a way I can strengthen the intensity by re-wiring it? Series or parallel?
I'm not even using that third mini-bulb either
I found these two topics, but any more help would be cool too.
kzrider.com/component/option,com_joomlab...id,4/id,92053/#92053
kzrider.com/component/option,com_joomlab...,4/id,116091/#116091
Thanks
Post edited by: fallenknight308, at: 2007/06/16 19:20
Post edited by: fallenknight308, at: 2007/06/16 22:09
Thanks
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
- PLUMMEN
- Thank you received: 104
16 Jun 2007 20:05 #150100
by PLUMMEN
Replied by PLUMMEN on topic new headlamp kinda weak
(wireman filling in)check/clean all your connections 1st;) whats the wattage of bulb?
- fallenknight308
16 Jun 2007 21:22 #150109
by fallenknight308
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
Replied by fallenknight308 on topic new headlamp kinda weak
# Each bulb is 20W for a total of 60W
# Two 36° flood bulbs in the center; third bulb is a 10° pencil
So I guess I'm running 40w total with the bigger two?
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
- Rickman
16 Jun 2007 21:51 #150111
by Rickman
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
Replied by Rickman on topic new headlamp kinda weak
measure the voltage at the headlight connector. if it is less than the voltage you can measure at the battery, the difference between the two (hopefully not very much) is the voltage drop. old connectors can be the cause, like at the fusebox or at relays. Or old wiring can cause it.
40W isn't very much, I think the stock is probably 55? Interesting headlight -- I don't think we're allowed three bulbs for the headlights in my state..
- katjbus
- Thank you received: 3
16 Jun 2007 23:17 #150116
by katjbus
Replied by katjbus on topic new headlamp kinda weak
That looks way bad a!@, like it alot, good luck, verify your grounds and wirring conections
- fallenknight308
16 Jun 2007 23:34 #150121
by fallenknight308
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
Thanks. I didn't check local laws concerning this light here in CA (probably banned )
So stock is 55w, its making more sense now. if the voltage is fine, the only way to get brighter is to prolly put different bulbs in there.
If I'm not allowed to use this on street I'll have to chalk this up to $85 lost.
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
- Biquetoast
- King Jeremy The Wicked
17 Jun 2007 06:48 #150155
by Biquetoast
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
Replied by Biquetoast on topic new headlamp kinda weak
kz750twins.com
- RetroRiceRocketRider
- Thank you received: 29
17 Jun 2007 15:31 #150253
by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic new headlamp kinda weak
I don't see why you couldn't use that headlight on the street.
The Kawi VN2000 Vulcan has a similar tri-headlight system, and I've seen quite a few of them prowling the roadways here in So Calif.
One of the members of a club I belong to owns an '06 or '07 VN2000.
I saw how INCREDIBLY bright they are just yesterday evening at a club members b-b-q, even on low beam! :ohmy:
It could possibly be an issue since it isn't the OEM headlight for your bike, but I say run it anyway! :evil:
I've seen a plethora of worse non-OEM equipment (3-foot tall rear spoilers and bazooka-sized exhaust on the Honda/Acura/Toyota/etc "slot cars" for example :sick:) infractions that rarely garner a single look from the local po-po.
Post edited by: RetroRiceRocketRider, at: 2007/06/17 18:32
- KZJohn
17 Jun 2007 18:52 #150277
by KZJohn
Replied by KZJohn on topic new headlamp kinda weak
I ran a PIAA Bright White H4 bulb in my 900. It was rated at 85w's for both the low and high beams. Yes it is illegal in CA. but so is speeding and I do that all the time! Run the light. Plead ignorance if you get pulled over however unlikely that will be. I never was,( for the light LOL).
