Newer Replacement Handlber Switches?
- Muddy
16 Jun 2007 13:14
I doubt any newer bike's switches are a direct swap for a kz650 CSR, but are any candidates better than others? The previous owner was an idot and went bat shit with black rattlecan paint on the windjammer fairing origianlly on my bike. There is overspray on everything, engine, exhaust, switches, etc, etc. And then decided to strip out all the screws holding the throttle side on. Just to get it off I had to get creative with a dremel.
I'd also like to update the look of the switches a bit. They are just ratty and old looking. I was thinking something from a newer sportbike. Any ideas?
- OKC_Kent
Re: Newer Replacement Handlber Switches?
16 Jun 2007 13:45
If it fits the handlebar and you can adapt the wiring it should work. All they are is a different looking switch.
Here are some links to aftermarket stuff.
www.epfguzzi.com/SWITCHES.HTM
tinyurl.com/2sdlpp
tinyurl.com/2sdlpp
Cashion, OK
78 KZ650 B2 85,000+ miles
- sheik*yerbouti
16 Jun 2007 14:30
www.kandstech.com/index.php?page=switchescontrols
You can't buy direct but you can find them on eBay always from a big outfit. They are on my Kz1000 cafe bike.
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
16 Jun 2007 14:50
On ebay where and what should I use to search for them?
- Muddy
16 Jun 2007 15:25
sheik*yerbouti wrote:
I was looking at these. I know the lh side k&s switches will work, but what did you use for the rh side? I saw they have one part #12-0200. Did you use this? And how does the throttle tube/cable fit?
I was thinking about using part #12-0030 far the lh side. Is this what you used?
- Mark Wing
16 Jun 2007 23:31
Yorba Linda Cal.
Yorba Linda Cal.
- Mark Wing
16 Jun 2007 23:31
Yorba Linda Cal.
Yorba Linda Cal.
- StreetfighterKz
17 Jun 2007 07:02
I have pn #12-0030 on my 1000 and used a Zx-12 RH switch (which is the same thing as pn #12-0203) along with a Magura throttle housing for the right side.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- bill_wilcox100
17 Jun 2007 08:36
Mark Wing, nice job, great lettering... man now I really need to clean mine up.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- austin3119
17 Jun 2007 09:02
Dang Mark. Nice job on the switches. I thought about doing that, but I didn't think I could do a good enough job on the lettering. I just threw in the towell and ordered a few new ones from Jeff at z1 . Not 100% exact replicas but pretty close.
- Mark Wing
17 Jun 2007 11:05
Thanks, it's not that hard. Everything comes apart and the letters are recessed. I did the bodies in lacquer and the letters in enamel. Let the bodies dry a couple days so their good and dry then flood the recesses with enamel the right away wipe off the extra paint with a smooth rag with some paint thinner on it. I used a old t-shirt and just a little thinner. Wipe softly so you don't dig it out of the recesses. I used Testors model paint.
Yorba Linda Cal.
Yorba Linda Cal.
