ignition
- spider
ignition
29 Dec 2005 06:49
hi gang how can i tell what kind of ignition i have on my z550ltd 1983 modle its not points i know that . im trying to do the coil mod for a better spark but things are just not going right help please i can't do wireing to save my life.
spider....
spider....
- fergyfer
Re: ignition
29 Dec 2005 08:29
My 80 550LTD had pickup coils instead of points, from the factory. I don't have the wiring diagram on your 83, but I'll bet it has the same ignition as mine had, unless someone has changed it.
Either way, if you go to the Filebase and on the right side click on the coil power from battery link, you can download the instructions there. It is pretty cut and dried. Let us know what problems you are having doing the mod or understanding the directions... Someone here can help.
You could also shoot a picture of it (your ignition) and either post here or email it to me and I'll post it...
Do you have a shop manual?
Post edited by: fergyfer, at: 2005/12/29 11:31
Post edited by: fergyfer, at: 2005/12/29 11:32
Post edited by: fergyfer, at: 2005/12/29 11:34
- loudhvx
Re: ignition
29 Dec 2005 09:28
That bike uses a reluctor-pickup assembly with a variable dwell (100 deg to about 120 degrees crankshaft) driving a transistorized ignitor. The ignitor uses ignition coils of about 2.5 ohms, but can handle coils with higher ohms.
Theoretically, the positive side of the coils can be wired permanently to the positive terminal of the battery with no switch at all. The ignitor doesn't give the coils a ground unless the engine is turning. But it's always safer to put a switch in line.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- wiredgeorge
Re: ignition
29 Dec 2005 12:12
Geeesh l-hvx! Didn't you hang out in a pool hall instead of going to school like a normal kid? Bwhahaha
- loudhvx
Re: ignition
29 Dec 2005 13:03
wiredgeorge wrote:
:huh:Geeesh l-hvx! Didn't you hang out in a pool hall instead of going to school like a normal kid? Bwhahaha
1981 KZ550 D1 gpz.
Other links.
Other links.
- spider
Re: ignition
30 Dec 2005 02:46
thanks for the great advice guys it realy helped so thanks again
spider....
spider....
