Dyna-S worth upgrading over Stock Ignition?
  • ZoomVroom
  • ZoomVroom's Avatar Topic Author
15 Jun 2007 13:44
#149713
I have a 1980 Kz750H with 14,000 miles. I have had a lot of problems with the carbs and currently working on those now. When the bike was running there did not seem to be any ignition problems I could discern. I already have 3.0ohm dyna coils which I am going to install... my question is: Is a dyna-s ignition a worthwhile upgrade over the stock kawasaki electronic ignition IF the kawasaki ignition is essentially fully functional? What would I gain from the upgrade?
1980 KZ750H1 - 14k miles - To much \\\\\\\"redo\\\\\\\" work to list!
  • BSKZ650
  • BSKZ650's Avatar
Re: Dyna-S worth upgrading over Stock Ignition?
15 Jun 2007 13:58
#149717
if the stock electronic is working , then I would say no
77 ltd1000, current rider
76 kz900, just waiting
  • N0NB
  • N0NB's Avatar
  • Blue handles better
15 Jun 2007 14:44
#149729
I would say that the only way the Dyna would be an improvement is if the stock unit isn't holding time. Check it with a timing light and if it looks like the mark is jumping around on either pickup at idle or full advance, you'll probably want to consider replacement.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • The Milkman
  • The Milkman's Avatar
15 Jun 2007 17:07
#149761
Dyna is a good improvement over stock but Wiredgeorge's relay for the coils mod helps even more. Replacing the 26 year old coils with new ones doesn't hurt either.
Ride safe.
  • badboie
  • badboie's Avatar
15 Jun 2007 18:03
#149783
upgrading your coil will give your spark a hotter spark thus allowing you to burn more fuel. This will create a better running bike, better exhaust, and a bit of a HP gain. The better your combustion is the more HP you get. You might see anywhere between 3 to 5 hp gain. But overall your bike will run a lot smother. :cheer:
  • loudhvx
  • loudhvx's Avatar
17 Jun 2007 06:57
#150157
The Dyna S will use twice as much power as the stock Kaw electronic. It will drain your charging system if you idle a lot (traffic, stop lights).
