Spark Plug boots
- SuperTrey
Spark Plug boots
13 Jun 2007 13:28
what effect can cracked spark plug boots cause? My number 4 is actually to the point of having a piece of the outside plastic broken?
- patmann
Re: Spark Plug boots
13 Jun 2007 13:36
Misfires come to mind:whistle:
Pat
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- SuperTrey
13 Jun 2007 13:41
rough running, backfires, extra vibrations, rich fuel smell sound about right?
- Rickman
13 Jun 2007 13:44
If the spark jumps out the crack, it won't fire the spark plug. this is a misfire. you might hear it as an irregularity in the exhaust note. If your hand is near, you might feel it as the spark enters your hand and jumps out your thigh to the frame. Ow! Remember with the dual-wire coils on the 4-cylinder bikes, the charge travels down one wire, thru the plug, thru the head, thru the other plug, and back up the other wire to the coil. If you have the timing light hooked up to the other wire in the pair, when it shorts you'll notice the light skipped a beat. Aside from the 'lectricity getting out, dirt and moisture can get in.
My wires didn't even look bad, but after noticing the above things (including the OW when I touched a wire while sitting on the running bike) I replaced mine and was glad I did. I bought a nice cheap set of wires from Z1enterprises.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- SuperTrey
13 Jun 2007 14:49
i guess that would also make the bike feel like it was missing at a constant throttle too?
