Just the basics
  • KzJim
  • KzJim's Avatar Topic Author
Just the basics
28 Dec 2005 12:41
#14891
I looking for a scaled back wiring diagram to use as a starting point for my new electrical system. something scaled back for a chopper would work nicely... thanks
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
  • OnkelB
  • OnkelB's Avatar
Re: Just the basics
29 Dec 2005 03:44
#14978
Here are a few links that should help you - esp. the last one has a lot of great info:
kzrider.com/forum/viewthread.php?tid=24450
www.ripper1.com/tech/wiring/
www.btinternet.com/~jhpart/bkwirec.htm
77 KZ 650 B1, 82 GPz 1100 B2.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Just the basics
29 Dec 2005 06:14
#14994
It would certainly help if you explained what electrical accessories you planned on putting on this harness. You will need a fuse block and one circuit will be for the ignition. Are you planning lights, horn, etc? Essentially, you will also need to describe the way power is being generated... alternator? stator? Are you planning on using a regulator or a combined regulator/rectifier?
  • KzJim
Re: Just the basics
29 Dec 2005 08:15
#15015
WG.. im using the generator and the regulator/rectfier setup... I worked on it last nite... when i get a bit farther ill post a PDF file (its in ACAD format now) to let someone elses eyes look at it.....
OnkelB.. thanks for the links.. i neede the bosch relay one
