1977 kz650c1 not charging?
- loudhvx
Re: 1977 kz650c1 not charging?
09 Jun 2007 07:14
Patton wrote:
But this guy makes some that will.
www.oregonmotorcycleparts.com
Post edited by: loudhvx, at: 2007/06/09 10:14
Unfortunately, that unit won't work on a 77 KZ650.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
09 Jun 2007 09:00
Thanks to loudhvx for the link to Oregon Motor Cycle parts.
Strange but true -- some stand alone voltage regulators are servicable (as here) while other's aren't (such as KZ900). The combo unit from Z1E works just fine on KZ900 replacing both regulator and rectifier with single direct plug-in. Perhaps due to some obscure phenomenon from the sinusoidal dimension :huh: but am afraid to ask
Here's the OMC part VR2-KZ650 listed for KZ650B and early KZ650C models ($47.50).
OMC also lists VR2-U without spade terminals and with pair of three-prong plugs (red to positive, black to ground, green to field coil) ($48.00).
Always hoping for the simple fix, and that wiring corrections and possible regulator servicing will resolve the electrical problems.
Wishing for you good luck with the repairs.
- loudhvx
09 Jun 2007 14:18
Yeah, the sinusoids are ok but...
really, it just comes down to the type of alternator. The 77 650, and some kz400's use an alternator with an electromagnet instead of a permanent magnet. The regulator is different for those type alternators. The rectifiers are basically the same electrically, but not physically.
1981 KZ550 D1 gpz.
Other links.
Other links.
