Acewell speedo/computer
03 Jun 2007 15:00 #145952 by Fossil
Acewell speedo/computer was created by Fossil
At first I was kinda disappointed with the performance of the Acewell speedo, but now that I've had a chance to finish the wiring, setup the speedo magnet and sensor, and program the unit, I'm pretty happy with it, especially the price.
Pic of Acewell magnet epoxied to rim, sensor is tie wrapped inside the fender parallel to the rim/magnet.
06 Jun 2007 10:03 #146875 by kawtoy
Replied by kawtoy on topic Acewell speedo/computer
Have you checked the accuracy with a GPS? Just curious how far it is off, or if it is off at all.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
06 Jun 2007 10:28 #146879 by kzwolfsr
Replied by kzwolfsr on topic Acewell speedo/computer
I did the same thing but I have cateye
Original man of the Caribbean
06 Jun 2007 10:31 #146881 by kzwolfsr
plus I set the speedo to 187 or 186 for wheel size and I use those speed radar signs to check my speed to see if its correct. As for your 16 inch wheels I am not sure if what to do
06 Jun 2007 11:53 #146899 by Fossil
Replied by Fossil on topic Acewell speedo/computer
Nope, don't think it's accurate - I think it's reading lower than the actual speed, though I haven't had a chance to check it to anything. The Acewell instructions do provide a number to punch in for 17" wheels so it is calibrated correctly.
06 Jun 2007 12:18 #146903 by kzwolfsr
I wouldn't go by what the instructions say if its for a bicycle. My computer is actually set to something close to a 24 inch wheeel, so just look out!
06 Jun 2007 13:27 #146927 by Allshookup
Replied by Allshookup on topic Acewell speedo/computer
I am looking at buying one of the Acewell 2753 gauges very soon. After everything is said in done would you recommend them?
06 Jun 2007 13:27 #146928 by Allshookup
06 Jun 2007 14:31 #146934 by Fossil
They're specifically made for motorcycle, ATV and automotive use.
06 Jun 2007 14:41 #146935 by Fossil
For the price, compared to what other motorcycle computers go for, yes. For a custom look, or to make it legal, sure, but you do only get what you pay for.
The only reason I bought one was because I didn't have a speedo drive on the wheel I used and somebody here "highly recommended" it, but turned out that was before he had installed it.
Stock factory instruments are way better.
06 Jun 2007 14:51 #146939 by Voodoosoup
Replied by Voodoosoup on topic Acewell speedo/computer
I believe it is supposed to be installed perpendicular to the magnets travel and in the same direction as the "vibration" in which case this would be the motion of the forks up and down. Then the center of the magnet has to cross the sensor at the line at either end.
I haven't taken anyone out to pace along side yet, but it seems fairly accurate. I also wrapped a piece of masking tape around my front wheel and marked it where it overlapped. I then took it off and stuck it to the garage floor and measured between my two marks to get the true circumference of the wheel. I converted the measurement to mm and entered it into the gauge.
06 Jun 2007 14:59 #146943 by Fossil
That makes sense, I read "direction of vibration" as a bad translation with vibration meaning rotation. Now the "lines" mean something. Thanks. I'm going to remount the pickup now.
