dyna s trouble
- udder
dyna s trouble
30 May 2007 16:20
i have dyna coils and s ignition. went through it and static tested it and it was ok tdc on both 12 volt light light on. now my question is the pick ups i believe ( the replacement outter part for your points) how is that set? is the plate it mounts to supposed to have timing marks as well? bikes coughing and i have power loss. was checking these out and they were loose musta moved them a bit when tightening. could i test to see when the coils are starting to get voltage is that a good set point when its tdc? should i retard a bit ?
Post edited by: udder, at: 2007/05/30 19:21
- BSKZ650
Re: dyna s trouble
30 May 2007 17:34
go to the dyna web site, look in install section, also has a trouble shoot section
77 ltd1000, current rider
76 kz900, just waiting
- N0NB
- Blue handles better
Re: dyna s trouble
30 May 2007 18:13
Read the instructions on page three carefully, the light should not turn on at TDC. You have the hold the rotor at full advance (clockwise) and adjust the plate so the light turns on point at the right hand advance mark. Then verify 2/3 (right hand pickup) matches.
It's an important detail that I didn't catch until I reread each step thoroughly.
I just noticed you have a KZ1000. I don't know if there are differences between the two. If the Dyna instructions are different than what I wrote, ignore my ramblings.
Post edited by: N0NB, at: 2007/05/30 21:15
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
