#3 Cylinder Dead
- carguy1996
#3 Cylinder Dead
30 May 2007 09:55
Am I missing something? I have spark, good compression, when the bike is running I can unscrew the drain plug on that carb and gas comes out. 1,2,4 pipes get hot but #3 I can touch just semi warm Anybody? I just put on new wires and plugs too.
- mariozappa
Re: #3 Cylinder Dead
30 May 2007 10:05
Just because you have gas in the carb doesn't mean it's getting into the engine cylinder.
You may have to take your carbs off and clean out the passageways.
Can you smell gas in the cylinder when you remove the spark plug?
1977 KZ650C1
and the KZ650/KZ750 Conversion
- carguy1996
30 May 2007 10:15
I smelled a slight hint of gas Then ran out of time Going to check that again today and pull carbs off again I have cleaned them out 2 times already
30 May 2007 12:16
Some possibilities --
Assure proper adjustment of #3 pilot mixture screw (might be too rich).
Check service fuel level in #3 float bowl (clear plastic tube method). Might be too high. Does it match levels in other carbs?
Pay particular attention to cleaning pilot circuit: pilot jet; air passage; air jet (if applicable); fuel passage.
Assure enrichener (choke) is completely closing on #3 carb.
Good Luck!
Good Luck!
- mariozappa
30 May 2007 12:35
Patton list some good possibilities.
If you've had the carbs off twice already and you're sure all the passageways are clean, then check some of his suggestions.
I had a problem like yours before, and I ended up going through the carb again and used compress air to blow a chunk of gunk out of my pilot circuit that I probably never would have found other wise.
1977 KZ650C1
30 May 2007 12:52
When using carb cleaner spray from aerosol can, please remember to use protective goggles. This toxic stuff backfires a lot.
- cuddies
30 May 2007 13:08
Patton wrote:
You should wear safety glasses at all times ;)
- mariozappa
30 May 2007 13:16When using carb cleaner spray from aerosol can, please remember to use protective goggles. This toxic stuff backfires a lot.
Yeah, I definitely learned that one the hard way! :huh: :sick:
1977 KZ650C1
- carguy1996
30 May 2007 15:26
Thanks Patton and to all else that chimed in I focused in on the pilot jet and passage and that seemed to do the trick it is firing on all 4 now. I just took it for a ride and it rode great. (now just have to fix oil leak from checking valve adjustment) but thats an easy one
