push button starter
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
push button starter
25 May 2007 02:12
#143326
i was wondering if i can hook up a push button starter to a 1977 kz 650. can i just hook it up to the relay? does anybody know what this involves, if so please let me know............thanks alot
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • The Milkman
  • The Milkman's Avatar
Re: push button starter
25 May 2007 06:10
#143350
I'm stumped. Other than your electric starter with do you mean by "push button starter"?
  • StreetfighterKz
  • StreetfighterKz's Avatar
25 May 2007 08:56
#143388
Are you trying to do away with your handlebar switches and trying to relocate a "starter button" somewhere else? I must say that I also am stumped.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Fossil
  • Fossil's Avatar
25 May 2007 16:34
#143498
I replaced the right side switchgear with a stainless steel sealed momentary starter button designed for boating application. Mounted it in a hole drilled in the upper GSXR triple clamp. In a word, yes you can. If your starter and kill switches are the same button, you'll have separate it and mount it elsewhere or do away with it as I did.
