yellow and red wires on the coils
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
24 May 2007 22:47
#143319
hello all, i have a question. i just updated the stock coils on my 1977 kz 650b with green 3.0 ohm dyna coils, in the process of switching them i some how broke the connector were the two yellow and red wires from the coils connect to the yellow and red one in the main harness. my question is can i connect the 2 yellow and red wires together and put a male connectorand a female connector on the main harness and be ok? or will i have to find a connector like the origanol? thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • The Milkman
  • The Milkman's Avatar
Re: yellow and red wires on the coils
25 May 2007 06:18
#143353
As long as the wires are connected to each other the same a they were in the original plug you can replace any of them that you want.
ride safe
  • OKC_Kent
  • OKC_Kent's Avatar
25 May 2007 07:09
#143363
Now would be a good opportunity to do Wiredgeorges coil mod. That connection is involved in it.
tinyurl.com/3dsj3x
Cashion, OK
78 KZ650 B2 85,000+ miles
