Quick question on stock coils
  • hobodan
  • hobodan's Avatar Topic Author
22 May 2007 22:22
#142654
Hello all! I just have a question on identifying some coils I have...
I have 2 sets, one set that fits the frame of my 77 kz650 b1 and the other set is slightly larger. I am assuming the larger ones are not correct, but maybe they could work? I dunno, here are the pictures:
Set that fits: (click to see bigger)
[img
[img
[img
Set thats off: (click to see bigger)
[img
[img
[img
They have model numbers off them, but I can't find any information on them.
The set that fits: ZC002-12V
The set thats off: ZC006-TR12V
I also talked to a guy who has the same model bike but its an 81, and his numbers were ZC001-12V
so i dunno, if anyone has information on them and perhaps even the specs, that would be great! or could just let me know if the set that fits will work.
Thanks!
-Dan
1977 KZ650-B1 frame and engine. Random pile of parts for the rest.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Quick question on stock coils
23 May 2007 05:13
#142701
You have either points or an IC igniter type ignition. Either will work fine with 3 Ohm (primary resistance) coils. Use a multimeter to measure the resistance on the primary windings... put meter leads on two small lugs where power and ignition wire connect with the meter in lowest Ohms scale. A reading between 3 and 4.5 Ohms indicates the coils would work OK for your application regardless of the mounting issues.
