Basic Electrical
  • hobodan
  • hobodan's Avatar Topic Author
Basic Electrical
21 May 2007 16:41
#142128
Hello again everyone! I hope you are all well!
I am trying to compile a basic diagram for the wiring of an engine for the kz650b
This is what i have so far:
www.bradyshome.com/kz650bwd.jpg
but i don't know what that extra blue wire is off of the contact breakers is. also, if you could let me know if this would work that would be awesome!
The generator is not their on purpose because i have a constant 12 volt source. but eventually i will include all of the other stuff. but now i just want to see if i can get the engine started.
also, which coil goes to what cylinders?
Thanks again everyone!
Post edited by: hobodan, at: 2007/05/21 19:44
1977 KZ650-B1 frame and engine. Random pile of parts for the rest.
  • KaZooCruiser
  • KaZooCruiser's Avatar
Re: Basic Electrical
21 May 2007 16:49
#142131
You might go here:
wiring diagrams
and see if there is some help there.
I think the blue wire is for the oil pressure switch. It is on mine.
:cheer:
  • loudhvx
  • loudhvx's Avatar
21 May 2007 23:20
#142293
Yes, blue is the oil pressure switch.
Total-loss electrical system? I.E. no charging system?
  • hobodan
21 May 2007 23:22
#142294
yeah, that was what I was using to figure it out, i believe that is the basic concept on how it works so i will try it out and check voltages and what not... and the oil pressure switch eh? i guess it must be underneath the breakers. thanks!
  • hobodan
21 May 2007 23:27
#142295
WELL, yes and no. I have all the components for the charging system, but I'm a poor starving college student trying to resurrect this motorcycle to save on gas, and living out of an apartment and using the back of my truck as a garage, I need to test things before I put it all back together. My landlord doesn't like me putting random motorcycle parts on the back porch, so I need to get the engine operational so I can get the bike build in one fell swoop.
