Turn Signals Dead
- indycycleworks
Turn Signals Dead
21 May 2007 07:35
Hey guys,
New to the forum and to KZ's. Just picked up a 1976 KZ900 A4 for cheap and am going through it, making a few modifications as I see fit. She runs, all other electrical works, except the turn signals. The stock ones do not work and I put some new universal short stock mini signals and if you wire them normally, the blinker solinoid clicks, but the signals do not blink. If you cross the wires and turn the turn signal switch on, the lights come on solid and bright, but the binker solinoid does not click. I am at a loss as to what it could be or how to trouble shoot it beyond this. At least I know everything else works fine. Any and all help would be greatly appreciated.
Nick
Nick
- OKC_Kent
Re: Turn Signals Dead
21 May 2007 08:04
Are these LED blinkers? Maybe that is it. I think the power draw is smaller and the flasher can't work right, but I'm not knowledgeable on this stuff. Look here,
tinyurl.com/2gy4ay
Do you know why the stock ones did not work? If the connections are correct and clean it could be a bad bulb or flasher relay.
Post edited by: OKC_Kent, at: 2007/05/21 11:06
Cashion, OK
78 KZ650 B2 85,000+ miles
- indycycleworks
21 May 2007 16:09
They are standard light bulbs, and I do not know why the stock units do not work. I am leaning toward the signal relay being bad. I would think that if the wiring was bad in some spot, it would not work if I crossed the polarities, but the lights did work. Do I need a specific relay or will any relay unit work?
