Dyna, vs. Accel, vs. stock coils
- snorules
20 May 2007 15:31
I finally figured out my KZ550C1 gremlins, my 2-3 coil is bad. I didn't check the resistance, but it has a big crack down the under side (the bike sat for years until I rebuilt it), and it produces almost no spark. I replaced the plug wires, ad did the coil mod. I also switched the coils just to make sure it wasn't the wiring coming from th cd igniter. 1-4 worked fine hooked up to the 2-3 side, but 2-3 still didn't work hooked up to the 1-4 side. I'm trying to figure out which new coils to go with, dyna, accel, or stock replacements. Also, does anyone know if these Emgo coils from Z1 will work with my bike?
www.z1enterprises.com/detail.aspx?ID=2857
Thanks in advance for the help.
Post edited by: snorules, at: 2007/05/20 18:32
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
- wireman
Re: Dyna, vs. Accel, vs. stock coils
20 May 2007 16:17
jeff lists 1.5,2.2 and 3 ohm coils for the 550.id call and ask him for sure;)
- udder
- loudhvx
20 May 2007 20:13
With the stock electronic ignition, the Accel 3.0 ohm work well. Coils with 2.2 ohm primary would be slightly on the low side, but could work fine if the inductance was similar. Stock would be closer to 2.4 or 2.5 ohm.
1.5 is a no-no.
I would say the 4-ohm Emgo's would be a bad idea. They are "slow" coils for points. (The electronic Kaw ignition uses smaller dwell angle than points Kaws.)
Post edited by: loudhvx, at: 2007/05/20 23:15
1.5 is a no-no.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- snorules
20 May 2007 20:41
Thanks for the advice, I'll give Jeff a call tomorrow. I thought about buying some used on ebay, but my luck I'd get bad ones.
