what would cause stator wires to melt?
  • boomboom45
  • boomboom45's Avatar Topic Author
17 May 2007 05:44
#140881
my stator wires got so hot they fused together. anyone have any ideas what caused this? i already checked the output at the battery, and its sitting steady at 14 volts.
  • The Milkman
  • The Milkman's Avatar
Re: what would cause stator wires to melt?
17 May 2007 06:23
#140900
Are you saying the battery is showing 14 volts with everything off or with it running even with the wires meted together??
I would check the ground wire for the voltage regulator, the regulator tranfers the over voltage from the alternator directly to the ground. If that wire is not making good contact it will send the excess to the battery instead and toast it.
Or, if one of the stator wires gets grounded that will toast the stator. Do the stator tests in the manual and see if that is the problem.
Post edited by: The Milkman, at: 2007/05/17 09:25
  • boomboom45
17 May 2007 07:03
#140914
no, i fixed the fused wires, and im getting 14 volts with the bike running.
  • boomboom45
23 May 2007 11:46
#142803
just an update, both voltage regulator, and stator have been tested and are functioning as they should be.
  • loudhvx
  • loudhvx's Avatar
23 May 2007 17:23
#142906
Dirty connections will heat the wires such that the insulation will melt near a connector.
  • ronjones
  • ronjones's Avatar
23 May 2007 17:37
#142910
The 1st time I rehooked my stator back into my harness, I didn't plug them in far enough :blush:...must have shorted to the frame or together, but they fried back to the stator.:whistle:
