instrument panel compatability
  • arobsum
  • arobsum's Avatar Topic Author
12 May 2007 13:04
#139439
will an instrument panel assembly from a kz650 work on a 1979 kz1000? will the speedo/tach cables match up? does it mount the same? thanks for the help.
  • RonKZ650
  • RonKZ650's Avatar
Re: instrument panel compatability
12 May 2007 20:06
#139564
I don't know about the wiring, if you're doing the whole panel, but the tach and speedo from a KZ650 will work fine on a 1979 KZ1000 except the redline is different and the KZ650 speedo only goes to 140 where the 1000 goes to 160. This is on the KZ1000A and B. KZ1000 shaft is a whole different thing alltogether.
  • arobsum
13 May 2007 08:09
#139648
well, its going on a 1979 kz1000 shaft. i found this setup for my son. his was messed up. so this will not work?
