ground on a 1974 z1 900
- oldkaws4ever
- Have no regrets...... You only live once.
11 May 2007 22:49
i recently replaced the worn battery cables on the 900 with a snazzy set fron Z1 enterprises. when i was taking the cables off i managed to snap the bolt that grounds everything off to the motor. is there another place that i can ground everything off at? there are three wires, one ground fron the rectifier, one from the electrical block, and the negative battery cable.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- AR15Ron
Re: ground on a 1974 z1 900
12 May 2007 00:15
It's not super critical where it grounds to the motor, only that it has a good ground to the motor. Find any other good bolt in a convenient place that isnt going to effect the engine or let oil out.
