HELP - Picture of battery leads/connects please?
  • Strizzzo
  • Strizzzo's Avatar Topic Author
  • 78 Kz1000A
Re: Picture of battery leads/connects please?
15 May 2007 15:05
#140380
Annnnnnnd - result.
Post edited by: Strizzzo, at: 2007/05/15 18:05
78 Kz1075A2
Portland, ME
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
15 May 2007 19:06
#140443
Strizz...that WHITE wire,that LOOKS like it's attached to the white/red wire...does it come from the fuse-box?If so...it does NOT get connected to the negative terminal of either the solenoid,or the battery.
On MY bike(and like I said,I got rid of the rec/reg,but for the most part,it's still the same)...
In the attached pic,You'll see that I have a WHITE wire that goes to the POSITIVE side of the battery.It's connected to a splitter,and from there it splits off to both the back of the solenoid,(POSITIVE side),and also the fuse-box,(MAIN).
SO...from the fuse-box,that wire ties into the back of the solenoid,and also the battery.
So let's start there,and see...
Post edited by: Sandy, at: 2007/05/16 00:53
1977 KZ1000 A-1
  • Strizzzo
  • 78 Kz1000A
17 May 2007 15:28
#141068
Sandy,
Thank you very much for the useful info. I ran the white straight to the positive battery mount and have retried my efforts. unfortunately I can't get it to turn over - sounds like it's about to catch and then nada; to be repeated until battery dies. The charge again.
The latest round now yielded the negative battery post having been melted in a simillar manner to the picture of the positive. Any idea if this could be caused just from draining it heavily or have I good and wrecked something in the electrics....?
Thanks for all the help so far.
78 Kz1075A2
Portland, ME
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
17 May 2007 16:38
#141088
Hi Strizzo.
You're welcome for the help Bud,and I wish I could do more,but it's really difficult when I don't really know exactly what You have going on.
Chances are...You fried Your battery,Bud,and hopefully that's all.
When You charge the battery fully(with a low amp charger...1-2 amps)You'll have to see how many volts it's holding.Wait about an hour and see if the volts drop dramatically.If it still holds a solid 12 volts,and not under 12,(not connected to the bike at this point either,ok)then I would GUESS that the battery is ok,but can't say for sure.It might APPEAR to be fine,but it would need to have a load put on it to be sure.
I'm not the "Guru" when it comes to this sort of stuff,but I can help out with SOME trouble-shooting.
Do You have a volt meter?If You do,go and see what volts You're getting off the battery right now.
I wonder if maybe You shorted out the starter solenoid?
Anyway...see what volts are on the battery if You can...
1977 KZ1000 A-1
