voltage regulator
  • boomboom45
  • boomboom45's Avatar Topic Author
voltage regulator
10 May 2007 06:44
#138837
i think i just fried my second voltage regulator, anyone have any ideas on how to track this down and fix it? its on a 79 sr650
  • mariozappa
  • mariozappa's Avatar
Re: voltage regulator
10 May 2007 06:48
#138841
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • boomboom45
10 May 2007 07:23
#138853
thanks, ill try this. but where should i start looking for the prob. last night my system is charging at 10 volts at 2500 rpm. i noticed the smoke come off the yellow wires coming from the generator to the regulator. could the seperate diodes be bad?
  • mariozappa
10 May 2007 07:26
#138855
Did you check the voltage coming from the stator?
I'm not familiar with you charging system as my 77's are a little different.
1977 KZ650C1
  • boomboom45
10 May 2007 08:02
#138871
if you mean by hooking up a voltmeter to the battery than yes.
  • mariozappa
10 May 2007 08:07
#138872
No, I mean by unhooking the wires running from the stator and measuring voltage there, while running.
Do you have a wiring diagram?
1977 KZ650C1
  • boomboom45
10 May 2007 08:59
#138896
in the clymers? manual i do. which one is the stator?
