Brake light staying on
  • 78KZMAN
  • 78KZMAN's Avatar Topic Author
06 May 2007 07:01
#137517
Hello all,
I have a 78 KZ1000 that I bought new with only 14,000 miles. Last week I had some new tires put on as well as some front brake work. All they really did to the front was change the brake fluid. Anyway, after I picked the bike up, two things were wrong. The speedometer cable broke (it's old so it could have just been its time)and my brake indicator light remains on at all times. Is there something that could have been done to cause this when the service was done?
Thanks,
Tom
Re: Brake light staying on
06 May 2007 07:19
#137520
78KZMAN wrote:
... brake indicator light remains on at all times....
Just a thought --
Believe that may be a brake light failure indicator light. Which might possibly result from one or both wires not being properly connected to the front brake pressure switch. :)
Edit: Would also check rear light bulb to assure tail light is illuminated when headlight is turned on, and that rear brake light is illuminated upon application of either front brake lever or rear brake pedal.
Check tail light bulb to assure both filaments are intact (i.e., neither filament is burnt out).
Post edited by: Patton, at: 2007/05/06 10:30
Post edited by: Patton, at: 2007/05/06 12:44
  • 78KZMAN
06 May 2007 08:20
#137529
I think I may have solved the problem. Down by the rear brake pedal is some kind of a switch that activates the brake light. I messed around with that and found it to be somewhat loose. After playing with it for awhile, the brake light & indicator went off. I guess I was assuming it had something to do with the work that had been done.
Thanks for your help!
Tom
