Electronic Tach
  • dnhnky
  • dnhnky's Avatar Topic Author
Electronic Tach
01 May 2007 14:34
#136171
Has anyone used any type of electronic tach. My tach doesn't work and my drive gear also went south a couple nights ago. It appears to be bent and has heavy marks from the cam gear. No chunks missing, but if it had run any longer I sure it would have been completely stripped.:blink:
Now I need a whole new set up, just wondering if anyone has come accross some type of electric/ electronic tach that will work and is reasonablly priced. (under $200). I plugged the hole in the head with a spare tach adapter that I welded up. Thanks for any suggestions, Dennis
  • shaftie1100
  • shaftie1100's Avatar
Re: Electronic Tach
01 May 2007 14:44
#136175
Hi,
I have an 83' 1100LTD, an it came standard with an electric tach. After smashing my instrument cluster to pieces, I've not been able to find an exact replacement. I have instead hacked out the full gauge cluster from an early 90's Vulcan. It works perfect... since it's a genuine Kaw part, all of the wires are properly color coded. You just need to open up the two quick-connects and swap out their housings.
If you can't find a tach from a Vulcan, check out this eBay auction for a different tach I found... this should also work for you with a little bit of modification.
eBay auction
Post edited by: shaftie1100, at: 2007/05/01 17:46
Post edited by: kzrider, at: 2007/05/01 18:12
  • dnhnky
Re: Electronic Tach
02 May 2007 09:01
#136442
Thanks for the info, I wasn't sure something from a newer bike would work with my old point ignition system. I guess I can check with a local shop that has some odds and ends. It's just sometimes that guy doesn't think outside the box. He told me that I couldn't fit 750 pistons in my 550 Honda and that the 750 carbs would fit/work either. It does seem to be running though.
  • KaZooCruiser
  • KaZooCruiser's Avatar
Re: Electronic Tach
02 May 2007 09:45
#136450
Seems an aftermarket automotive unit would do the same thing, as long as it is set to the correct scale.
  • Voodoosoup
  • Voodoosoup's Avatar
Re: Electronic Tach
02 May 2007 15:47
#136535
I'm going to be putting one of these on my bike soon.
www.electrosport.com/electrosport_speedo_2700.html
  • dnhnky
Re: Electronic Tach
03 May 2007 12:22
#136826
Thanks guys, I did check out that site and was wondering if anyone had any experience with them. I thought about an automotive one and was trying to think about the signals for the tach and settings and got a headache from thinking about it. I have one of those universal ones for a 4-6-8 cylinder auto. I guess I could hook it up and see what it does. I think I have a project for when I get home this evening. My only other concern for an auto one is waterproofing. I'll let you know if it works.
  • dnhnky
Re: Electronic Tach
03 May 2007 12:22
#136827
Tried the auto tach, it wasn't reading fast enough. If I could get the sinals from both coils it might work, but that would require some diodes I think. I'm not always that good with the electrical stuff. I'll try to see if I can get a motorcycle electronic tach locally.
Post edited by: dnhnky, at: 2007/05/04 07:17
  • KaZooCruiser
Re: Electronic Tach
07 May 2007 09:08
#137882
When you say it wasn't fast enough, do you mean it didn't respond quick to change in input, or that it read half of rpm?
I know I would miss a tach, but I'd miss a speedo a lot more.
  • loudhvx
  • loudhvx's Avatar
Re: Electronic Tach
07 May 2007 09:45
#137891
It would read half the RPMs (in 4cyl mode) because it only gets half the signals. It needs the signals from both coils, but it takes an adapter circuit. Unfortunately, a bike with 180 degrees dwell needs a slightly more sophisticated adapter to work right.
Here's one for a bike using the Kaw electronic ignition (120 degrees dwell), but it won't work on points. I hope to design one in the future for the points bikes as well. If you do a search, you might be able to purchase one, but it sucks paying $20 to $50 for $3 worth of parts.
