starter part # crossover
  • tcbradbury98
  • tcbradbury98's Avatar Topic Author
27 Apr 2007 18:07
#134816
Does anyone know if any other starters from other kaw bikes will fit on mine? I need to replace it. I'm having trouble finding one. Part number is 21163-1031. Thanks
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: starter part # crossover
27 Apr 2007 18:46
#134829
Here ya go.
1980-83 KZ 550 LTD, GPZ KZ550 KAWASAKI Starter Motor - Remanufactured Unit Comes With One Year Warranty !!!
Or cheaper yet! KAWASAKI STARTER KIT 1980-83 KZ 550 LTD, GPZ,KZ500 ;)
Just curious, why do you feel you need to replace your starter?
If it just spins and won't turn the motor over, or spins and catches periodically, that's usually the starter clutch. A completelty diff critter than the starter itself.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • tcbradbury98
27 Apr 2007 21:45
#134910
The starter catches occassionaly, it will work fine for a few starts and then won't catch for a few starts. I figured it was like a car starter and it was easier to replace the starter, what exactly is the starter clutch? thanks
27 Apr 2007 22:51
#134917
Unlike an automobile starter, the geared shaft on our KZ starters isn't spring actuated to extend and mesh with the engine to turn it over, and that's where the starter clutch comes in.
I imagine the 550 is similar to the 650 since it's engine is loosely based on it, so the starter clutch should be located directly above the oil pump.
Exhaust and oil pan removal is required to be able to access it. So get yourself a manual, a rebuild kit, and set a weekend (or more if you're not familiar with motorcycles) aside to perform the repair.
If you do a search in the archives, you'll find quite a bit of info on exactely what you'll be in for.
In fact, OnkelB posted quite a great write up including pics when he rebuilt his starter clutch.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
  • mstbone67a
  • mstbone67a's Avatar
29 Apr 2007 08:19
#135221
so its like this one then cgi.ebay.com/ebaymotors/Kawasaki-KZ550-m...dZ1QQsspagenameZWD1V
crap that looks very internal lots to take apart LOL
  • JMKZHI
  • JMKZHI's Avatar
Re: .
29 Apr 2007 09:36 - 03 Dec 2008 11:43
#135253
del
Last edit: 03 Dec 2008 11:43 by JMKZHI.
