Troubleshooting
  • Bicycle Lee
  • Bicycle Lee's Avatar Topic Author
Troubleshooting
24 Apr 2007 12:56
#133532
So I ride an old, decommissioned police bike...among all the switches is one that turns the headlight on and off...
I've found that when the headlight is switched off, my bike idles great, but as soon as I switch the light on it sputters and eventually dies.
What's the deal? How can I remedy this? Is it the charging system?
1978 KZ1000 police
  • ltdrider
  • ltdrider's Avatar
Re: Troubleshooting
24 Apr 2007 13:12
#133536
Sounds like the headlight is drawing more juice than the bike can make at idle.
Does it only falter at idle? If so, then maybe your battery's not holding a charge. The generator doesn't send much current to the battery at idle, and if your battery can't store it up, then there won't be enough juice for the coils. At about 3000 rpms, the problem should go away, if your generator is working right.
...OR...
Your headlight may be drawing more current than it should due to bad/dirty connections. Or you may have a super brite upgraded headlight bulb that draws more current than the original bulb. The original bulb draws 35W on low beam, and 50W on high beam, but upgrade bulbs can draw 85W, and they can tax your charging system, especially at idle.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • Bicycle Lee
Re: Troubleshooting
24 Apr 2007 13:55
#133546
It goes away as the rpm's increase, so my normal performance isn't affected, only idle is fluttery. My battery is brand new and holds a great charge, but I don't know anything about the bulb that's in there
1978 KZ1000 police
  • BSKZ650
  • BSKZ650's Avatar
Re: Troubleshooting
25 Apr 2007 04:52
#133729
I wonder if the charging sysetm is working right, or you still have something going to ground from the old system
77 ltd1000, current rider
76 kz900, just waiting
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Troubleshooting
25 Apr 2007 07:59
#133797
Lee,a standard bulb will be 55/60 watts.
You should pull the bulb out and have a look at it,to see what wattage it is,to be sure.
I know others have,and are using a higher wattage bulb,and with some rewiring and a relay,it can work.
1977 KZ1000 A-1
