Another Problem.......
- Skully
24 Apr 2007 06:08
OK,
After sorting out the starter relay wiring problem, another weird thing is going on. The turn signals work with the headlight off, but WON'T work with the headlights on.........WTH??????
I'm getting real close to firing this thing off!
Thanks,
Jim
Thanks,
Jim
- Sandy
- Fly High,Tony
Re: Another Problem.......
24 Apr 2007 08:22
Is this going on while the bike is running,or not?
I'm thinking that You have a low battery,and with the headlight lit,there's not enough juice to power the signals.
What about the brakelight?...does IT come on with the headlight on?
Bad charging system?
Still using the factory rec/reg?
1977 KZ1000 A-1
- Skully
24 Apr 2007 08:28
Sandy,
This is with the bike not running, and since I use a pressure switch for the brake lights, and they aren't hooked up yet, I can't tell about the brake light. When I put a meter on the battery, it will read from 11.5-12.2v, and I was kinda thinking the same thing (low battery)so I will charge it some more, since it doesn't spin the motor over very good.
And yes, still using stock reg/rec.
Thanks!
Jim
Post edited by: Skully, at: 2007/04/24 11:30
Thanks!
Jim
- Sandy
- Fly High,Tony
24 Apr 2007 08:36
Ya Jim...get that battery charged,and if You CAN...get the bike running and then see what volts You're getting at the battery,and also,try the signals then.
Is the signal flasher an old(er) one?
And how old is the battery?
1977 KZ1000 A-1
- ronjones
24 Apr 2007 10:14
Again, I'm gonna say to check for loose/broken connections and bad grounds. Most of the time I've seen things like: "not working when X is on but works when X is not or vice versa. Almost everytime I've experienced this it ends up being a ground wire. What will happen is that the device is looking for someway to get to ground and finds that way when something else is turned off or on.
Just my 2 cents, hope you find the problem
Ron
Ron
- Skully
24 Apr 2007 18:14
Thanks Guys,
And the answer is......... LOW BATTERY!!!! I've been charging it for the last few days with a battery tender, so I got out the trusty 2/12/75 amp charger and charged it on 2 amps for a few hours. It still isn't strong enough to crank it, but I finally broke down and used the 75 amp cranking to get it to fire off. Anyway..... New battery will be here Thursday and fork lowers will be done Friday, so should be riding it this weekend!!
Thanks Again!!!
Jim
Thanks Again!!!
Jim
- Sandy
- Fly High,Tony
24 Apr 2007 21:43
Right on Jim...glad You figured it out,Bud!
And what Ron said about ground wires...too true,and often the case in situations like that.
I remember going through all that with My rear signals,a few years ago...not fun.
1977 KZ1000 A-1
