headlight upgrade
- Booncha57
headlight upgrade
23 Apr 2007 19:11
while im fixing my headlight that is out i was wondering if anybody has done anything to improve the output of their light. this thing is as good as a lantern out there. i guess the charging systems on this bike arent very good so you shouldnt put higher wattage bulb in there but has anybody gotten results from something else that were worth talking about?
- StreetfighterKz
Re: headlight upgrade
24 Apr 2007 03:59
Perform a search. This has been discussed before a couple of times. All the info you need is already in the forums.
Later, DOug
Later, DOug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- KZJohn
24 Apr 2007 07:29
If your still using a sealed beam lamp you should change to a H4 conversion. I have one on my 900 and have had no problems. I went so far as putting a PIAA "Super white" bulb in it with an 85w low beam. It was bright enough at night that I could see well even with a tinted visor. Yes the charging system will struggle to keep up. I have gone through the elect syst on my bike and have cleaned up or repaired most of the connections to minimize voltage drop and make the syst more efficient.
- Booncha57
24 Apr 2007 10:58
thanks, do you think i can pick up something like that at an advance auto?
- Booncha57
24 Apr 2007 10:59
- ronjones
24 Apr 2007 11:36
I'm pretty sure they do have them.
- RonKZ650
24 Apr 2007 11:49
Don't use an automobile bulb or it will be burned out whithin a week. This is how it's been in the past anyway. Maybe now discount auto supply bulbs are better? I doubt. They don't hold up to vibration a motorcycle has. Go to a motorcycle dealer and get a headlamp.
- KZJohn
24 Apr 2007 13:26
The PIAA bulb I used was made for bikes and lasted over a year. I ride alot so thats a long time. The bulb burnt out on the way home and I put in an H4 from a nearby auto parts store. I guess I'll find out how long that one will last.
- Booncha57
